are the 410 and 413 alternator the same?
I know the standard 410 alts are 40 amp and the 413 55 amp, but I want to know if a 413 alt will bolt straight in place of a 410 alt as mine is knackered and isn't charging anymore and i have a 80 amp hour battery that i need to be able to charge, so I have to keep jumping my zuk using a caravan battery I have in the boot..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
- timwilks13
- SCUK Website Padawan
Re: are the 410 and 413 alternator the same?
i know that i was unable to fit my 410 alternator on a 413 block as the mounts are closer together on the 410 alternator. Also the wiring is slightly different on the 413 alternator than the 410.
- suzukisteve
- Suzuki Guru
I remember seeing someone on here adapt a transit alternator. However I cant remember who or what engine
pickle power!
it was a transit alternator with a vacuum pump on the back of it... the pump ended up getting removed though
- suzukisteve
- Suzuki Guru
think I need to find out what alternator is on mine then cause its a Mitsubishi alt 55 amp.. I thought it might be a 413 alt cause they are 55 amp
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
- suzukisteve
- Suzuki Guru
what year is yours as ill look it up while im here at work
pickle power!
find a local auto electricians
My local motor factors wanted £190 for an alt
electricans fixed it for £28
1987
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
