largest tyres on standard lift
- timwilks13
- SCUK Website Padawan
Re: largest tyres on standard lift
if it works out gettin these tyres ill cut the outriggers off and fold the seam and we can see at wagtail if they fit! The main reason i want some bigger tyres is because im running the 1.3 engine and gear box but through my 410 transfer box so will hopefully get a bit more speed out of larger tyres!
Looking at he pictures of your SJ you seem to have quite a bit of arch in your springs? I wonder if it has actually got lift springs fitted?
can yu get some decent pictures? looking at the amount of arch gap you have I think you'll be ok with those tyres
Ans with a 410 tbox and diffs it will be geared well
- timwilks13
the fronts I got off jordi so hopefully he can confirm if they're lift springs or not, looking to get some lift springs for the back when some crop up. ill take some better pics tonight with my camera as my phone seems to restart every time I take a picture...!?
Has 4x4rick sold his smjs that he had for sale on the breaking scooby post
SJ 410 currently off road waiting to leap out of hibernation.
Please visit wifes web site http://www.apassionforcakes.co.uk/index.htm you might even find a zuke on there :-)
- timwilks13
This is my front and rear wheels, currently running 195's, there might be enough room at the front, not so sure about the back, sits a bit lower, but i could lift the back with some slightly longer shackles if i cant get any lift springs soon.
- 2013-08-14 15.52.41.jpg (1.28 MiB) Viewed 6381 times
- 2013-08-14 15.52.49.jpg (1.5 MiB) Viewed 6381 times
The fronts look like they could be lift springs
the rears are standard though.
I couple of Suzukis back I had a '92 Samurai that has 215/75r15 BFG Muds and that needed no mods at allScottieJ wrote:235/75r15 fit a stock height sj with a bit of trimming to the standard front bumper and mounts.
I run 235/75r15 BFG Muds on my current '88 SJ and had to trim the front bumper mount a little...to be fair I need to get the grinder on the case again and go a bit further
Paul
- IMG_2439.JPG (3.73 MiB) Viewed 6376 times
- 143-4325_IMG.JPG (403.39 KiB) Viewed 6376 times
maybe a little bit of extra length on the rear shackles for now and run 235s?
u will need to chop the the front bumper brackets off flush with the chassis and bang the lips back in the arches
Just fit as big as you can afford and cut the body work to match.
