Power steering
Modified
Power steering
Post by Modified » Fri Aug 09, 2013 6:39 pm
Hi there, i have been told the a jiimy power steering system fits an sj just wanted to double check ?
4x4rick
Re: Power steering
Post by 4x4rick » Fri Aug 09, 2013 6:47 pm
Modified wrote:Hi there, i have been told the a jiimy power steering system fits an sj just wanted to double check ?
yes and I have 1 for sale..........
will list it monday
Re: Power steering
Post by turbo-tom » Fri Aug 09, 2013 9:25 pm
well it does but dont.
best way to do it is
1.research.
2.Jimny steering box.
3.vitara pump.
4.vitara resivour
5.vitara pipe work or get yourself some hydraulic hoses made up.
Re: Power steering
Post by Jordi » Fri Aug 09, 2013 10:00 pm
Jinmy box is a straight swap but the steering column needs the plasic pegs drilling out and shortening slightly.
I have a G16 with Vit pump fitted. None of the pipes really fit properly, thay can be bodged on but i got custom pipes made up. Price for these varies rapidly, i paid very very little, some firms will charge upto £100.
If your fitting it to a G13 you need to get a double bottom pulley made or off a vit/jimny and mix and match all the pulleys (alternator, fan, PAS to match). Also need to make up a bracket to fit the pump properly.
Modified
Re: Power steering
Post by Modified » Wed Aug 21, 2013 8:59 pm
Thanks so to do it i need power steering box, pump, hoses and a resevoir anything else ?
4x4rick
Re: Power steering
Post by 4x4rick » Wed Aug 21, 2013 9:12 pm
Modified wrote:Thanks so to do it i need power steering box, pump, hoses and a resevoir anything else ?
as my post above...
i have a jimny p/steering kit.....I brought it from tristan.(minimog) on difflock
he stripped it from a sami... I should have most if not all the parts you need
....I never used it myself as I was running a vauxhall/carlton P/Steering...
R
Modified
Re: Power steering
Post by Modified » Wed Aug 21, 2013 9:28 pm
How much ?
4x4rick
Re: Power steering
Post by 4x4rick » Wed Aug 21, 2013 9:43 pm
Modified wrote:How much ?
it wont be dear.....
let me have a sort out at the weekend (c what I have)
if you want to PM me a mobile I can send u a pic of parts I have...
R
