SAMURAI PEPPERPOT WHEELS
zuke sammy
Post by zuke sammy » Sun Nov 01, 2009 5:44 pm
i want to get my sammy pepperpot wheels refurbished to there former glory they are on my 1995 single point injection sammy she is my show car so i want them as they would have been when they left the factory they have been painted in the past and they are now starting to show there age my anus is mint but the wheels really let it down where can i get them back to how they should be?
cheers mark 8-)
Henry
Re: SAMURAI PEPPERPOT WHEELS
Post by Henry » Sun Nov 01, 2009 6:14 pm
Well firstly a good sand/shot blast would be ideal.
Then they need to go straight into primer once shot blasted. Then the hard work starts.. Lots of coats of heavy build primer (sanding between coats) Then once happy, a goot wet and dry will get the finish good. You can then spray them in what ever colour you like.
Be careful when applying the top coat tho, you can put too much paint on and it will spoil the overall finish. After top coat applied, i would suggest leaving them for 1 week minimum to harden completely.
Henry
