identify vitara engine
- Cyprus Geoff
- Can I have a tow
Re: identify vitara engine
Ok, - finally, the pics as promised:-
- Eng1.jpg (205.84 KiB) Viewed 3775 times
- Eng2.jpg (263.33 KiB) Viewed 3775 times
G16a.
1.6 8v Carb
Spot on!
1.6 8v Carb
Spot on!
Looks like its already got the 1300 clutch cable bracket, and sump too (hard to tell from photo) and I presume 1300 clutch and flywheel too.
The previous owner has fitted a sammy bottom pully and alternator which uses a v belt. If you are thinking of fitting power steering you will have to swap to a vit alternator and a double 4pk pully. No biggie though.
- Cyprus Geoff
- Can I have a tow
Hmm, it did come of a Sammi as I got the conversion plate wiv it.
Tell me about the clutch please, as that was my main reason for posting - I intend to peplace the clutch and sort of assumed the 1.6 would be stronger. FWIW I currently have Jimny pas fitted to my 1300 and will transfer that over.
EDIT - OK, done some reading and I see it is the 1300 clutch you need - hope it is man enough for the job?
Although my clutch went on saturday, I find the 1300 clutches cope quite well.
When I had the 8v engine it was in there for 5 years I think... same standard clutch in there, and I only changed it after putting in the 16v engine.
