su accelerator bracket help
timwilks13
SCUK Website Padawan
Post by timwilks13 » Tue Jul 23, 2013 1:08 am
I'm using a hif44 from a pair but neither pair has any sort of fixing for an accelerator cable, had a look to see if I could bodge on something from my aisian carb but to no avail. its a hard problem to explain but i need something like on the old aisian carb where you have a bit of bent channel that the cable sits in...sorry if I'm not explaining this very well, but here is the su without the bit I could do with.
kibris
Re: su accelerator bracket help
Post by kibris » Tue Jul 23, 2013 8:51 am
timwilks13
Post by timwilks13 » Tue Jul 23, 2013 9:43 am
thanks kibris but its where the throttle attaches to the butterfly that I'm missing, ill Photoshop something together tonight to explain.
timwilks13
Post by timwilks13 » Tue Jul 23, 2013 11:35 am
this is what I'm after, can anyone confirm it will go on my hif44?
Post by Darrell » Tue Jul 23, 2013 11:35 am
This bit??
timwilks13
http://www.ebay.co.uk/itm/SU-HIF44-1-Ca ... 1055739366
timwilks13
Post by timwilks13 » Tue Jul 23, 2013 11:36 am
yea that bit, didn't see your post till I posted that Darrell sorry!
Post by twiss » Tue Jul 23, 2013 12:25 pm
Its worth checking out sucarb.co.uk
Maybe give them a call and find out which one is best
http://sucarb.co.uk/levers-throttle-stops.html
Post by Darrell » Tue Jul 23, 2013 9:02 pm
As Twiss said give them a ring. I've found this but don't know it its correct. Some SU's have a little tag with a number on for identification.
http://sucarb.co.uk/cam-lever-19084.html
timwilks13
Post by timwilks13 » Fri Jul 26, 2013 10:05 am
thank for your help guys, still havent found the exact bit im looking for, but all the above has been brilliantly helpful!! and i will continue to search, but in the mean time i have take the throttle arm off my old aisian carb, cut off the extra stopper arm bits and just bolted it on the the current SU throttle. Bit of a bodge but seems to work, ill put up a picture later if and when i remember to take one!
