Anyone made a bracket for vit 16v pas pump to fit sj410
ojr1979
Post by ojr1979 » Fri Jul 05, 2013 4:13 pm
As the title says? has anyone made a bracket to make the vitara 16v pas pump fit onto the sj410 engine? any pics or dimensions appreciated? cheers
Re: Anyone made a bracket for vit 16v pas pump to fit sj410
Post by turbo-tom » Fri Jul 05, 2013 4:52 pm
I bolted a 10mm steel plate to the side of mine and lined it up with the exsiting holes in the bolt holes then welded the pump bracket to th plate ;)
ojr1979
Post by ojr1979 » Sat Jul 06, 2013 9:28 pm
Well ive looked on every forum on the planet looking into this and everyone makes a bracket up! why? ive done it using the original one from the vitara! the single bolt hole in the tab i drilled out to 10 mm i also used two standard spring washers as spacers behind this to bring the pulleys inline and then i worked out where the other two holes would be admittedly i was half a hole out on my first attempt,i think the hole centres are 60mm? so i just elongated them slightly fits real nice to! saves time! Also went to a car parts shop and got a new belt to run the pas pump i cant remember size but it is the next size down from the vitara belt!
photo 1(1).JPG (1.53 MiB) Viewed 6466 times
photo 2(1).JPG (2.16 MiB) Viewed 6466 times
ojr1979
Post by ojr1979 » Sat Jul 06, 2013 9:32 pm
Post by Darrell » Sat Jul 06, 2013 9:34 pm
Good job :thumbup:
I think these pics/posts should be put with your pulley ones and kept as a stickie.
ojr1979
Post by ojr1979 » Sat Jul 06, 2013 9:35 pm
Just the wedge left to make now then ill do the whole thing in one for the stickies
Post by Darrell » Sat Jul 06, 2013 9:45 pm
The dimensions for the wedge are here http://forum.suzukiclubuk.co.uk/vi ... =15&t=2052 , but I expect you already knew that :oops:
ojr1979
Post by ojr1979 » Sat Jul 06, 2013 9:49 pm
Yeah already seen it mate but thanks anyway!
ojr1979
Post by ojr1979 » Thu Jul 11, 2013 7:19 pm
Only thing stopping me welding up the wedge now is im unsure if the 40mm tab sits inbetween the plates or if it is welded onto the back of the plates? anyone seen a better pic anywhere?
Post by Jordi » Thu Jul 11, 2013 7:25 pm
Bolt it all in place and tack weld it. Remove it and weld it up. Then everything should be in the right place.
