Wiring up spot lights
kgilmore
Post by kgilmore » Tue Oct 20, 2009 5:23 pm
Hi, im wiring up my spot lights using the guide on the DIY section, however it doesn't tell you the wire for the beam, does anyone know what one it is, because it would save me going though the handfull of cables under the dash.
Also the flash beam uses a different cable does anyone know what that one is?
Cheers.
Henry
Re: Wiring up spot lights
Post by Henry » Tue Oct 20, 2009 5:27 pm
You mean the full beam?
Why dont you just tap into it on the headlights, is there any need to go under the dash?
kgilmore
Post by kgilmore » Tue Oct 20, 2009 5:52 pm
well i put the relay is under the dash, dont know why, but the only reason why I want it on the beam is so i can turn all my lights off by using one switch.
Just need to know the pattern of the cable ie. red with yellow strand.
Cheers.
Henry
Post by Henry » Tue Oct 20, 2009 6:12 pm
What sj have you got?
kgilmore
Post by kgilmore » Tue Oct 20, 2009 6:29 pm
413
