Windscreen advice
ianedwards
Windscreen advice
Post by ianedwards » Thu Jun 27, 2013 2:08 pm
Afternoon all,
After some advice in the windscreen,
Is it best to put it in before putting the dash in or can I put the dash in and the windscreen later.
Also is it best to use some sort of sealer when putting he windscreen back in.
Ian
Ian. :)
Re: Windscreen advice
Post by turbo-tom » Thu Jun 27, 2013 2:29 pm
Id put screen in last so there isnt a risk of smashing it! ;) also the three top screws can be a pain in the arse to get out/ in as you have to use a stubby screw driver as there is limited acess coz od the screen.
ianedwards
Post by ianedwards » Thu Jun 27, 2013 2:56 pm
Yea thought as much. Can crack on then.
Ian. :)
Post by dan_2k_uk » Thu Jun 27, 2013 3:42 pm
I used no sealer and got a perfect seal but my paint was still a little tacky so it stuck like glue.
I would probably just fit it and if it needs it put a little polyurethane sealant under the outer seal after. I would have thought putting sealant round before inserting it could get rather messy!
Post by turbo-tom » Thu Jun 27, 2013 3:54 pm
Lost of lube prior to install!
Post by Jordi » Thu Jun 27, 2013 5:23 pm
No sealant required. Fit it last. Be gentle.
ianedwards
Post by ianedwards » Thu Jun 27, 2013 9:56 pm
Cheers.
Ian
Ian. :)
Post by twiss » Fri Jun 28, 2013 12:28 pm
ianedwards wrote:Yea thought as much. Can crack on then.
Don't say crack too loud ;)
Post by ScottieJ » Fri Jun 28, 2013 12:54 pm
Yeah don't do what I did!
ianedwards
Post by ianedwards » Sat Jun 29, 2013 5:27 pm
Lol, nice pun
Ian. :)
