rockwatt manifold and su hif44 carb pipe work help needed
Just got a rockwatt manifold with a su hif44 carb for my g16a engine but struggling to know where my water and fuel pipes go to. Any help welcome. Thx
Re: rockwatt manifold and su hif44 carb pipe work help neede
Three pipes on the front of the SU.
Far left (driver side) is fuel in. The top two are fuel overflow (top left) and breather (top right).
The very small pipe where next to the manifold, above the butterfly is the vac advance onto the dizzy.
Without looking i can't remember which water pipe went where.
These 3 first
- 20130624_125450.jpg (2.57 MiB) Viewed 7530 times
Not sure which pipes these 3 are
- 20130624_125634.jpg (3.03 MiB) Viewed 7524 times
Bottom left is fuel in, middle is fuels over flow and top left is breather.
The photo with the rubber pipes is
Fuel supply
Fuel return
To find out which is which spin the engine over, which ever spews petrol out is the supply the other is the return.
Vac advance - skinny pipe
Fuel supply
Fuel return
This is the water pipe that comes up from the top of the water rail
- 20130621_093858.jpg (2.31 MiB) Viewed 7515 times
Fairly sure that goes onto the manifold at the back.
In the pic of the 3 rubber ones can I get rid of the t peice and just run the hose to the vacume?
Mine does. Mine never had a t piece in it.
On the water rail there is 1 big hose that goes to the thermostat, then there is a smaller pipe that goes to the manifold and one other smaller one which is in the picture which im not sure where it goes. I will try get a better pic of it up tomorow. Thx for ur help btw, owe u a beer at wagtail lolJordi wrote:Fairly sure that goes onto the manifold at the back.
