Clutch grinding and full Adjusted but no drive????
Post by Jordi » Thu May 30, 2013 2:30 pm
1600 is in, adaptor plate is on, gear box all bolted up lovely, just sild together.
Made a few final adjustments to fit it, engine mounts etc.....
Finally got round to seeing if it would move itself again and everytime i press the clutch a get a griding noise. Any ideas?
I've full adjusted the cable just about and i'm getting no drive.
Could it has anything to do with the thickness of the adaptor plate?
Re: Clutch grinding and full Adjusted but no drive????
Post by Jordi » Thu May 30, 2013 2:38 pm
Haven't sorted it yet but have had a brain wave to undo and move the clutch arm.
Post by Jordi » Thu May 30, 2013 4:06 pm
Moved the arm, adjusted the cable as far as it will go, still no drive???
Post by Jordi » Thu May 30, 2013 5:06 pm
Gonna be a gear box back out job. I have a terrible feeling due to the thickness of the adapter plate, 5mm, the clutch and gear box aren't meshing properly.
Post by ScottieJ » Thu May 30, 2013 5:15 pm
I can't really see that the adapter plate would be the cause of the problem as its only about 2-3mm thicker than the normal spacer, I've not heard about anyone having issues while running an adapter plate?
Post by ScottieJ » Thu May 30, 2013 5:26 pm
Have you checked your transferbox Jordi :middelfangers: :hahaha:
Post by Jordi » Thu May 30, 2013 5:44 pm
Yeah, that WAS ALL FINE! Cheers Scott!
Post by ScottieJ » Thu May 30, 2013 6:09 pm
Jordi wrote:Yeah, that WAS ALL FINE! Cheers Scott!
Not in neutral then? :middelfangers:
Post by dan_2k_uk » Thu May 30, 2013 6:23 pm
I replied to this earlier but my signal was too bad. Only said the same as Scottie anyway RE the spacing of the plate.
Dont know if it physically fits the wrong way but is the clutch plate in the right way round?
Post by ScottieJ » Thu May 30, 2013 7:18 pm
My father says he thinks the clutch plate is in the wrong way around listening to the vid.
