Onother Suspension question
ektoz
Re: Onother Suspension question
Post by ektoz » Wed May 22, 2013 1:52 pm
Am using rancho rs5113 on rears scott, its 20.25" / 12.88" Eye to Eye, they are good but hard
Jordi, i can find L200 shocks eazy but i think they will be hard as my rear ranchos
i was thinking of getting the same shocks as fronts and weld a eye at the top .
DAD... i need 60 euros for the rear shocks please????? :roll:
Don't grow up, it's a trap
My build thread:
http://www.suzukiclubuk.co.uk/forum1/vi ... hp?t=10402
Post by Jordi » Wed May 22, 2013 2:00 pm
I think Scott did something similar at one point.
Post by twiss » Wed May 22, 2013 2:13 pm
All I can say is, whatever you do, avoid pro-comp es3000s... most shocks use gas or oil, I think es3000s use cement
Post by Jordi » Wed May 22, 2013 2:14 pm
Cement filled shocks. Now theres an idea.
Cyprus Geoff
Post by Cyprus Geoff » Wed May 22, 2013 2:57 pm
Chris (EKTOZ) and I were discussing the possible use of L200 Hilux twin cab shocks - I guessed they would be way too hard just as you say Jordi, they are made for a MUCH heavier truck.
Son, our mutual friend in Nicosia has all my money :tongue:
ektoz
Post by ektoz » Fri May 24, 2013 11:10 am
pro-comp and rancho use the same Cement,;)
here what i have in the front and i will put also at the rear now, they are soft like butter :smokin:
My build thread:
Cyprus Geoff
Post by Cyprus Geoff » Fri May 24, 2013 12:09 pm
Hey Son they look good, what length open and closed?
ektoz
Post by ektoz » Fri May 24, 2013 12:14 pm
Daddy they are
70cm - 27,9⁄16 inches open
43cm -16,59⁄64 inches closed
My build thread:
Post by ScottieJ » Fri May 24, 2013 12:34 pm
ektoz wrote:Daddy they are
So 270mm travel (10.6") that's good to know, means they have just over 1" more travel than astra shocks.
Cyprus Geoff
Post by Cyprus Geoff » Fri May 24, 2013 12:41 pm
Good info "family" :-)
