Head gasket torque settings?
Evening chaps, has any got the torque settings for the bolts on the head gasket casing for a 1.3 Samurai engine please, thanks
- turbo-tom
Re: Head gasket torque settings?
Give me 30secs ill fire the pc up and get them for you
Tom
Ford Fiesta ST
Ford Fiesta ST
if in doubt, FLAT OUT!
Cheers buddy, much appreciated
no probs
- Ladaman
- Suzuki Guru
Starting from the middle, working out.
The final torque should be
63 - 70N.m
6.3 - 7.0kg.m
46.0 - 50.5lb-ft
I hope that helps.
Doh!! Too slow.
63 - 70N.m
6.3 - 7.0kg.m
46.0 - 50.5lb-ft
I hope that helps.
Doh!! Too slow.
It doesn't go unnoticedturbo-tom wrote:Way to slow I am
- turbo-tom
Haha and i dont think you have noticed something eithierJordi wrote:It doesn't go unnoticedturbo-tom wrote:Way to slow I am
Tom
Ford Fiesta ST
Ford Fiesta ST
Check again!
