dazerede
Post
by dazerede » Wed Apr 24, 2013 9:09 pm
Right I took my rear right drum off and It needs new shoes and cylinders but I seen my shoes on it naw have the thing for the handbrake a bit confused plus the rear break lines on my zook it Ts of straight from the braided hose pipe but my other 410 axle 100% is a 410 axle doesn't T off it goes to one cylinder and then goes to the other cylinder
I will upload pics tmoz to explain
Going to jack the rear up tmoz and take the prop of and all of the rear brakes as the are all fucked and make sure it is a 410 diff and axle
And I will need to get new shoes and cylinders I found this any good
Click Here for Ebay Listing
4” calmini lift kit
Post
by Darrell » Wed Apr 24, 2013 10:42 pm
All my diagrams show the pipes going to one cylinder then across to the other. IE pipe in-out and pipe in-bleed nipple.
However when searching for cylinders it showed the later model 410 using only one type. IE pipe in-bleed nipple. So assume this has a "Tee" fitted.
I would establish exactly what you have fitted now before ordering.
Here's what I found
- SJ 410 rear cylinders.jpg (205.38 KiB) Viewed 7037 times
Post
by Darrell » Wed Apr 24, 2013 10:48 pm
I also believe the shoes with the handbrake lever are also slightly larger than the ones without.
Best you get the tape measure out
Post
by Darrell » Wed Apr 24, 2013 11:10 pm
Seems like you have a later model 410 back axle by the sounds of it. According to the brakes website the handbrake on the rear drums was 1987 onwards (E reg>)
Nicked the shoe info now
- SJ 410 rear shoe types.jpg (104.96 KiB) Viewed 7030 times
- SCUK is my life
Post
by andyrew » Wed Apr 24, 2013 11:14 pm
Sounds to me that you have a spanish axle fitted and your spare one is jap.
Is the spare axle the one off the sj originally?
Post
by Darrell » Wed Apr 24, 2013 11:22 pm
Are the later models all Santana's or did they still make them in Japan as well.
Post
by Darrell » Wed Apr 24, 2013 11:53 pm
andyrew wrote:Sounds to me that you have a spanish axle fitted and your spare one is jap.
Sounds good to me
Looks like they built them in Spain and Japan to get around import limits
http://en.wikipedia.org/wiki/Suzuki_Jim ... .2FSamurai
dazerede
Post
by dazerede » Thu Apr 25, 2013 7:59 am
Chears darrell for the info when I bought it all I done was swap the front axle as I seen a sj in my local scrapyard and got the axles of that
Going to show some pics later
4” calmini lift kit
dazerede
Post
by dazerede » Thu Apr 25, 2013 9:09 pm
Right took my brakes of.my rear axle on my zook and off.my spare rear axle which are both 410 axles
Here are the pics of my brakes on.my zook
- Passenger side rear shoes and cylinder
- IMAG0282.jpg (1.13 MiB) Viewed 6993 times
- Drivers side rear shoes and cylinder
- IMAG0283.jpg (1.13 MiB) Viewed 6993 times
- Passenger side brakes on vehicle
- IMAG0275.jpg (1.34 MiB) Viewed 6993 times
- Drivers side brakes on vehicle
- IMAG0271.jpg (957.81 KiB) Viewed 6993 times
4” calmini lift kit
dazerede
Post
by dazerede » Thu Apr 25, 2013 9:11 pm
This is the brakes on.my spare axle
- IMAG0284.jpg (712.29 KiB) Viewed 6991 times
4” calmini lift kit
