Sj413 carb
Crisdolf
Sj413 carb
Post by Crisdolf » Sun Apr 14, 2013 8:59 pm
I believe it's auto choke,vehicle runs fine but you have to pump throttle when u start it cold and keep rev up till warm,when I was doing the filters other day and a general clean up I took top cover off carb and notice a cable holding flap shut ? Any ideas ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
penpontgreenwoodwork
Re: Sj413 carb
Post by penpontgreenwoodwork » Sun Apr 14, 2013 10:29 pm
mine had the same start up symptoms. I noticed the little pipe from below the green plastic valve on the off side of the carb had perished. Changed it, starts fine. :thumbup:
They don't make cars like they used to!
SJ 413, tin top.
Sammy front axle.
2"? lift Springs on front, shackles on rear.
On the road
Crisdolf
Re: Sj413 carb
Post by Crisdolf » Sun Apr 14, 2013 11:20 pm
Yes ,sorry first message should read cable tie in top hold flap shut ,there's wires to carb so I take it auto choke is electronic ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Sj413 carb
Post by Edweird » Sun Apr 14, 2013 11:28 pm
I thought the autochoke used some kind of thermal wax or something
Re: Sj413 carb
Post by ROBBIE » Mon Apr 15, 2013 8:06 am
Yep thats what i thought ed
Crisdolf
Re: Sj413 carb
Post by Crisdolf » Mon Apr 15, 2013 11:02 am
I'm not sure either will take some pics and put on
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Sj413 carb
Post by penpontgreenwoodwork » Mon Apr 15, 2013 6:49 pm
The standard carb auto choke is wax, it's on the left as you look over the driver side wing. Darrell posted all the carb diagrams up on the "standard 413 carb service" thread, shows everything. the cable tie is a mystery, I take it it's on the port nearest the engine?
SJ 413, tin top.
Sammy front axle.
On the road
Crisdolf
Re: Sj413 carb
Post by Crisdolf » Mon Apr 15, 2013 9:27 pm
Yes it is
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Crisdolf
Re: Sj413 carb
Post by Crisdolf » Tue Apr 16, 2013 11:30 am
This is it pics taken from drivers side wing
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Crisdolf
Re: Sj413 carb
Post by Crisdolf » Tue Apr 16, 2013 11:32 am
penpontgreenwoodwork wrote:mine had the same start up symptoms. I noticed the little pipe from below the green plastic valve on the off side of the carb had perished. Changed it, starts fine. :thumbup:
Yeah pipes a bit perished too,where can I get some ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
