Swapping water rails
How to swap water rails from 1.3 to 1.6.
Is it easy enough to do? Any pics?
Re: Swapping water rails
undo bolt, pull off, push on other one, do up bolt.
Don't i look like an incompetent doosh asking that now.
Size o ring please?
Took a while to find that
- number 5.jpg (80.71 KiB) Viewed 4248 times
Where do you get this stuff from?
And thank you.
And thank you.
I rob it all from here http://translate.google.co.uk/translate ... uki-cat.ru
O rings dimensions are normally the internal size, but it may be worth checking before/if you order any..
Click Here for Ebay Listing
Silly question do you have to swap when doing the 1.6 swap?
