spin each wheel individually other turns opposite (bit of a delay 1/5 of a spin 33" tyres) both do the same
got a brother to spin the same way wheels wouldn't rotate figured this was correct
so from that i put half shafts and possible diff out of line of being broken then i read about wiggling the transfer shaft to check the input bearing and wow does it move could this be the culprit ?
Any help will be appreciated!
