LukeyGTI
Post
by LukeyGTI » Thu Mar 14, 2013 7:37 pm
Alright everyone
bought my first SJ last weekend and im looking for a bit of advice,
currently it has a 1.6 8v Vitara engine on carbs with the 1.3 SJ box, which goes quite well, took it down a few green lanes by me and im chuffed with the way performed
but it all seems a bit old skool for me so was looking at getting a Diesel turbo engine, found a Daihatsu Fourtrak 2.8 Turbo engine for £250 they any good? has anyone else put this engine in an SJ??
Post
by Edweird » Thu Mar 14, 2013 7:44 pm
LukeyGTI wrote:Alright everyone
Most people decide against diesels in SJs because they're much heavier. If you're dead set though I think the Peugeot 1.9TD engine is the easiest option.
Post
by Tramp » Thu Mar 14, 2013 7:51 pm
You already have the best engine conversion installed, the vit engine is 20% more power for a slight increase in weight, I'd stick with the vit motor if I was you!
Post
by Jordi » Thu Mar 14, 2013 7:54 pm
2.8td is way too much.
SJs are small and light. Anything much more than a 1600 or 1.9 pug lump is a bit pointless. If you want power try a 1300 swift GTi or 1.5 Ignis lump.
If you do want to change it any engine you want can be put in with enough work.
OllieSJ
Post
by OllieSJ » Thu Mar 14, 2013 7:55 pm
Post
by dan_2k_uk » Thu Mar 14, 2013 8:58 pm
The video is a perfect example of why you want to keep it light, a bit less weight and he would have been straight through.
1.6 is all it needs. Only adds about 35-40kgs over the 1.3.
Think the Vit lump with all the extras is around 120kg a big diesel will be double that!
LukeyGTI
Post
by LukeyGTI » Thu Mar 14, 2013 9:17 pm
ok you've swayed me towards staying with the vitara engine! any tips to get the most out that engine?
another quick question, not engine related, noticed the front leaf springs were looking quite flat is this normal or should they have a curve in them?
dazerede
Post
by dazerede » Thu Mar 14, 2013 9:21 pm
Welcome to scuk post some pics of ur motor
Yep the best engine for a sj or samurai is a 1.6 vitara engine or a 1.9 pug engine
Also put ur location in on ur profile
4” calmini lift kit
dazerede
Post
by dazerede » Thu Mar 14, 2013 9:25 pm
The springs are like 20 plus years old there bound to be flat best to get new ones
The best place to.get springs is llama 4x4
4” calmini lift kit
Post
by Tramp » Thu Mar 14, 2013 9:49 pm
Generally speaking leaf springs should be curved, but most original SJ front springs are just about flat, even when they left the factory there wasn't much curve to them!
As for engine mod's, i think janspeed make a header for them and you can change your carb to something better, one of my favourite carbs is the weber 32/36dgv
