nothing coming from starter motor ??
ebooksgti
Post by ebooksgti » Sun Feb 17, 2013 1:06 pm
hi i just had my gearbox off my vitara due to clutch going but now its back together i have power going to the car but when i turn key nothing happens no noise at all
Re: nothing coming from starter motor ??
Post by Darrell » Sun Feb 17, 2013 1:47 pm
Have you forgotten to put the wire back on the starter solenoid. :S
dunnin21
Post by dunnin21 » Sun Feb 17, 2013 8:00 pm
Check fuse wire
gp7186
Post by gp7186 » Sun Feb 17, 2013 9:09 pm
Also if you have had the gearbox off make sure you have connected the main earth cable back to the bellhousing
Post by ScottieJ » Sun Feb 17, 2013 9:22 pm
What he said ^^^^ there's a big earth wire that is attached on one of the starter bolts.
Post by Darrell » Sun Feb 17, 2013 9:32 pm
ScottieJ wrote:What he said ^^^^ there's a big earth wire that is attached on one of the starter bolts.
Argh, but if you leave this off it starts, but your clutch cable melts :D
PS : I haven't done that :thumbup:
