New to site. My build so far!
Re: New to site. My build so far!
Post by dan_2k_uk » Sun Feb 03, 2013 8:20 pm
About 50mm so I hear.
dannytrigger
Post by dannytrigger » Mon Feb 04, 2013 1:28 pm
took it for a little drive today to see how she feal but couldnt get up the road! engine has developed a missfire and dies when under any heavy load?? it will rev up fine when in neatraul tho? smoked a little but no big white plumes. think im gona get compression tester out later and check it over. Also gona check spark. very tempted to rip it out and stick 1.6 in tho
Post by dan_2k_uk » Mon Feb 04, 2013 4:16 pm
If you havent changed the gearing yet I wouldnt be supprised if it couldnt move with 37s on and a cold engine!
dannytrigger
Post by dannytrigger » Mon Feb 04, 2013 5:21 pm
ye put a 410 transfer box on awating full floating axle. then gona get a t-box made up when the banks look a bit happyier! also going vit diffs
dannytrigger
Post by dannytrigger » Mon Feb 04, 2013 5:22 pm
surly it wpuldnt cause splutter and missfire tho?
Post by Jordi » Mon Feb 04, 2013 5:24 pm
Tyres those size i'd be tempted to go pug diesel.
Spluttering and miss fire may just be a poorly set up engine, timing most likely. A good service may sort it.
What carb is it running?
dannytrigger
Post by dannytrigger » Mon Feb 04, 2013 5:40 pm
ye put a 410 transfer box on awating full floating axle. then gona get a t-box made up when the banks look a bit happyier! also going vit diffs. been looking at vit 1.6 or ldv engine. The carb is hif44.
dannytrigger
Post by dannytrigger » Mon Feb 04, 2013 5:41 pm
sorry it copied last post aswell
Post by Jordi » Mon Feb 04, 2013 5:48 pm
Coughing and spluttering and missing sounds like timing.
Theres always this http://forum.suzukiclubuk.co.uk/vi ... lit,Ignis/ probably not the cheapest or easiest option but certainly power / weight wise it gives massive improvement.
dannytrigger
Post by dannytrigger » Mon Feb 04, 2013 5:56 pm
been reading up on a few engine swaps thinikng going g16a purly for easy option see how that perfoms then maybe chop in an ldv lump at a later date
