Brake master cylinder seal / rebuild kit
Post by Jordi » Mon Jan 28, 2013 2:25 pm
Any body know the part number and a stockist?
I've tried Brakes Int. and they reckon main stealer only.
Its been ooozing for about 6 years. Gets topped up every now and then. Figure if I'm gonna rebuild the calipers may aswell do this whilst i'm on. Saves bleeding it again later.
Re: Brake master cylinder seal / rebuild kit
Post by Jordi » Mon Jan 28, 2013 8:44 pm
Anybody?
Post by Darrell » Tue Jan 29, 2013 7:29 pm
The repair kits I've found cost more than a complete unit from brakesint. I have read that they often leak from the reservoir grommets. I see you have the earlier type and here are the part numbers. I have no idea if suzuki still keep any parts for them.
m cyl 2.jpg (71.24 KiB) Viewed 5271 times
sj413 master cylinder-servo.jpg (287.6 KiB) Viewed 5271 times
Post by Jordi » Tue Jan 29, 2013 7:37 pm
Cheers Darrell. 99% sure it is those two grommets when the reservoir sits in.
I'll try my main stealer see if they can help. I know the same grommets were also used on some Hyundai models so a scrap yard mission may also be on the books in a few weeks.
If i struggle it may just be a strip and clean and see how it goes.
Post by Jordi » Wed Jan 30, 2013 9:51 am
Easiest option first as said in my build thread.
With in 5 minutes Stonacre had the exploded diagram on his computer. Two rubber grommets on the way.
Post by Jordi » Wed Jan 30, 2013 9:54 am
Any chance of making a stickie out of this Scottie?
The pic made it so easy to explain to my dealer which parts i wanted. Most parts are still available apparently. Some are individual others are kits.
Didn't think £9.07 was too much of a robbery.
