Wanted LJ80 - Steering tie rod lever
Neil4x4
Post by Neil4x4 » Sun Dec 16, 2012 4:53 pm
Hi, I'm currently finishing off my LJ80 restoration - does anyone have a steering tie rod lever - the bush inside mine has perished
Many thanks,
Neil.
Re: Wanted LJ80 - Steering tie rod lever
Post by ScottieJ » Sun Dec 16, 2012 8:46 pm
Ill have a look I might do? One person who probably will is Abdul off the raging rhinos forum. I would actually try Suzuki as well, they do still have some Lj bits available.
juncopartner
Post by juncopartner » Mon Dec 17, 2012 12:37 pm
They were always a problem on LJ's, but they usually seize up and oval the mounting holes in the chasis, I always used to remove the bolt every year and coat the bolt with copper slip. I seem to remember that someone in the LJ register had one rebushed at an engineering works, think they may have used a bronze bush, but it was a long time ago so not sure now!!!
I will have plenty of spare ones, but not sure what condition they are in though. Hope to have a look at Xmas as I am going to start with mine shortly and need to clear garages out.
Neil4x4
Post by Neil4x4 » Mon Dec 17, 2012 5:24 pm
Guys, thanks for the replies.
My lever has lateral movement when I pull or push a wheel (when jacked up). I suspect the bush has perished inside.
I've tried a worldwide search on Google to find a new one but to no avail to date. If I can't get a replacement, I'll try and get it rebushed after xmas.
Post by Darrell » Mon Dec 17, 2012 9:04 pm
If you guys mean part 17 I bet Mr Rockwatt could machine a bush to fit it. What material is it as standard? as I see it has seals on it.
Neil4x4
Post by Neil4x4 » Tue Dec 18, 2012 7:32 pm
Yep, number 17 it is.
I think the original material was (now past tense) rubber with a metal insert(?). I heard people mention rebushing it with brass, which sounds like a great idea. I just need to find a fabricator in the Basingstoke area.
Um, anyone??
Post by ScottieJ » Tue Dec 18, 2012 8:30 pm
I did actually see one of these bushes new on eBay ages ago, have you tried calling a suzuki dealer?
Offroadrunner
Post by Offroadrunner » Tue Dec 18, 2012 10:28 pm
You can buy these parts new at the Off Road Shop in Germany. You have to bring some serious money...
http://www.gew24.de/index.php?cat=c752_ ... hebel.html
Groeten / Gruß / Regards / Salue / Salutare / Menyapa / 挨拶する, ]-[arold
http://www.offroadrunner.nl
http://www.suzukilj80.nl
juncopartner
Post by juncopartner » Wed Dec 19, 2012 12:34 pm
Any engineering workshop should be able to make a bronze bush, most big towns will have one, don't know about Basingstoke though. I live in the North East and there are still loads of engineering shops still around in spite of Thatcher trying to end all industry up here!!!
Priced a full arm up 25 years ago, think it was £79 + VAT back then, anyone know what they are now?
Just had a thought if you can buy them in Germany are they only for a left hooker????? They are completly different to the one on right hookers!!!!
Neil4x4
Post by Neil4x4 » Fri Jan 04, 2013 10:32 am
Hi guys, thank you all for your input; all very useful stuff.
My LJ is in fact left hand drive but I don't fancy paying £150 (ish) in Germany for a new one that doesn't look like my existing lever. So after much consideration, I've decided to rebush it myself, using a combination of the old bush insert and new rubber from axle bushes from my old MGB.
Failing that (which is probably the case), I've found a local company who will make a brass insert, acting as a bush but I'm a little worried about lubricating it, so not to make the steering stiff.
I'll let you know how I get on.
