1.6 engine swap,
mk1joe
1.6 engine swap,
Post by mk1joe » Sat Dec 15, 2012 6:43 pm
hi, i want to put a vitara, 1.6 8v carbureted engine in my sj410, but im to cheap to want to buy a new gearbox , i have the standard 4 speed so will it bolt straight to the gearbox? what else would i need to buy? do u use the clutch plate from the vitara?
thankyou
joe.
also does anyone have any pictures of this engine in this bay for me? thankyou:)
Re: 1.6 engine swap,
Post by turbo-tom » Sat Dec 15, 2012 6:54 pm
Hello Joe, This might be worth a read i understand its for a 1.3 engine but its pretty much the same.
http://www.suzukiclubuk.co.uk/diy/15-en ... 1-6-engine
Also being you have a 1.0 you will have to change the one of the engine mounts, to be honest i would say Scottie on here can tell exactly what you need to do being he has done it. ;)
ferris
Post by ferris » Sat Dec 15, 2012 7:07 pm
I think you need a 1.3 gearbox, flywheel and clutch.
mk1joe
Post by mk1joe » Sat Dec 15, 2012 7:57 pm
ok, so is there no way of coupling it with a 410 gearbox? even with a conversion plate, if anyone sells one?
Post by ScottieJ » Sat Dec 15, 2012 9:16 pm
The 1.3 flywheel is too big to fit into the bellhousing.
Sorry but using a 1.3 or the 1.6 gearbox are your only options
mk1joe
Post by mk1joe » Sat Dec 15, 2012 9:33 pm
oh thats a shame:( i imagine 1.3 would be easier. but how about making a 1.3 engine fit a 4 speed box? would that work? could i put a 1.0 flywheel on it?
Post by ScottieJ » Sat Dec 15, 2012 10:09 pm
fly wheel won't fit the 1.3, I wouldn't really class the 1.3 as an upgrade either, I prefer the 1.0!
dazerede
Post by dazerede » Sat Dec 15, 2012 10:13 pm
ScottieJ wrote:fly wheel won't fit the 1.3, I wouldn't really class the 1.3 as an upgrade either, I prefer the 1.0!
why have u got a 1.6 then
and also is the 1.0 gearbox mounts the same place as the 1.3 is
4” calmini lift kit :)
Post by ScottieJ » Sat Dec 15, 2012 10:22 pm
Because the 1.6 is a worthwhile upgrade and also means I have the stronger vit gearbox, a bigger clutch and have the option of the twin transfer boxes. If you have driven a 1l on 31s then you wouldn't ever run one with 33s!
On later 410s (fat prop) >around 84/85 the gearbox mount is in the same place, on early ones it isn't.
