coil springs
coil springs
Hi guys has any one done coil springs on a sj if so got any pics what springs did you use what mounts etc etc,
Or do you know of a thred with pics I can look at
Thanks Cookie
Thanks Cookie
Re: coil springs
IF YOUR HANDY WITH FABRICATING,, (OOPS left the cap locks on),, ford fiesta rear springs/shocks will go on.
Re: coil springs
Vit seem to be a fav too
- urbanzook
- Winching along now
Re: coil springs
im looking to use vit bits as im braking one but not to sure on how im guna do it.
Re: coil springs
Depends what setup you want... 2 3 4 link?
- urbanzook
Re: coil springs
well if you told me wot 2 3 4 links was id let ya no.
Re: coil springs
All depends how you want to make the axles fit.
The easiest is to use a vit axle on the rear, then you just need to chop the trailing arms down so they will mount in the old spring mounts. However deoending on what chasis you have will determin where you move the mounts on the axle too.
This is the 2 link setup
- DSCF2111.jpg (77.76 KiB) Viewed 10792 times
Re: coil springs
1 link front with pannard.
Flex will be limited with the springs and shocks on it. (second pic)
- 7236_13012008135_3.jpg (60.35 KiB) Viewed 10787 times
- 7236_07022008159_2.jpg (55.05 KiB) Viewed 10787 times
Re: coil springs
Another good read full of ideas if you want something a little different
http://forum.difflock.com/viewtopic.php ... usupension
Re: coil springs
If you want to go about it properly so that you get the correct geometry have a look at this guide
http://www.4wheeloffroad.com/techarticl ... index.html
