Spark plug leads
- lazy rambler
- Can I have a tow
Spark plug leads
Basically, I just need to ensure I have to right spark plug going to the right dizzy point.
Re: Spark plug leads
Mine is backwards to make the leads lay in a better order so dont ask me
Thought it was moulded onto the dizzy caps
According to the tinternet the Vit firing order is the same as an SJ, 1342 so --
Don't forget to make sure the dizzy is not 180 degree out
- Leads.jpg (104.96 KiB) Viewed 10827 times
- lazy rambler
- Can I have a tow
How do I make sure that it's not out by 180 degrees?
I knew you'd come through with a diagram Darrell
If you aligned the timing marks correctly if you had the belt off then just rotate the crank by hand untill the timing mark is aligned with the marks on the cambelt cover and check the rotor arm points towards lead number 1.
Probably best to get a timing light on it before you start trying to tune it aswell.
Dan
Dan
