Suzuki Ignis Engine in a Sammi
Re: Suzuki Ignis Engine in a Sammi
Post by Edweird » Tue Sep 11, 2012 12:56 am
Vorshprunk Dirk Suzuki
Ladaman
Post by Ladaman » Tue Sep 18, 2012 11:24 pm
Well I asked on as many forums as I know about, contacted lots of breakers on eBay with Jimny M13A engines trying to source a sump all to no avail. I even tried the local main dealer. That was a funny chat without a registration number!!
So I have started to make my own sump. I've never made anything like this before, and making it water tight was much harder than I expected!!
I chopped the original Ignis sump up keeping the mounting flange and the top 50mm (2"). Then using the remnants of a Strongbow box made a template, then got cutting in steel.
I still need to weld the flange on, make a baffle plate, adjust the oil pick up, before I can continue with the engine mounts, but progress is being made, albeit a it slower than I would have liked.
Post by ScottieJ » Wed Sep 19, 2012 9:20 am
That looks good matey! :thumbup: just make sure you take your time welding the flange on, last thing you want to do after all that work is warp it!,
Post by Edweird » Wed Sep 19, 2012 2:02 pm
That sump is looking boss! Nice job.
Post by Anton » Thu Sep 20, 2012 1:16 am
Ladaman wrote:I even tried the local main dealer. That was a funny chat without a registration number!!
I've had this problem in the past. I used autotrader.com to find someone selling the same model/year of car I'd nicked bits from to get a reg, and gave them that.
Ebay might work too.
Ladaman
Post by Ladaman » Mon Oct 08, 2012 9:33 pm
A major step forward has been achieved tonight, well I'm getting a little closer.
After a bout of "man flu" and finally getting some help from my son to line the engine up, which was a tricky job to ensure clearance in all the right places, and not having to mod the prop' shaft. I've finally managed to finish the engine mounts, and remove the engine from the block and tackle :lol:
I still have to fabricate something for the back of the gearbox, but that "should" be easy in comparison.
I might need to do a little mod to the sump as it is quite close to the front diff', but that's all part of the fun!!! :S
Below are a couple of pics of the mounts, I just need some slightly shorter bolts, and they should be finished. :smokin:
photo (1).JPG (1.72 MiB) Viewed 16785 times
photo (3).JPG (1.82 MiB) Viewed 16785 times
Post by ScottieJ » Mon Oct 08, 2012 10:05 pm
Nice work on the engine mounts matey, looks good :thumbup:
Post by dan_2k_uk » Mon Oct 08, 2012 10:08 pm
Awesome. Get that rear mount done and get her running for a video!
Ladaman
Post by Ladaman » Mon Oct 08, 2012 10:33 pm
Cheers Scottie.
dan_2k_uk wrote:Awesome. Get that rear mount done and get her running for a video!
Tell me about it!! I'm itching to get it running. I've got a crackin' exhaust lined up for it too :lol:
Lots still to do, but when I'm happy with the position of it all it should be a bit easier until the wiring!!!! :er:
Ladaman
Post by Ladaman » Thu Oct 11, 2012 10:32 pm
Well the gearbox mount is done now. As I thought it was pretty easy. If you remember back I made three machined rings for suspension bushes, and I was going to use the final one for the gearbox. While I was laid under the Zook I spotted the old gearbox mount still on the old Sammi box. Why not try to use that? All it required was the wedge cutting off the Jimny support, a plate welding onto it to make it 50mm longer, and re weld the wedge back on. Piece of cake.
I've got some DIY to do now for a week or so to keep the boss happy, so there won't be much progress for a short while :cry:
I can't complain, as she doesn't when I'm working / spending on the Zook
Plumbing next, water and fuel.
Getting there.
Gearbox mount4.JPG (1.73 MiB) Viewed 16548 times
Gearbox mount2.JPG (2.37 MiB) Viewed 16548 times
