Body/Chassis ground upgrade.. do it!
Jay18
Post by Jay18 » Sat Sep 15, 2012 7:56 pm
i have done an upgrade on my body ground to the battery and was suprised at the difference it made, i got rid of the small mostly broken wire that was there and replaced it with battery cable..
it really does make a difference, all of the interior lights were alot brighter and my radio seemed to work better too.
i found that the clutch cable bolts were a good ground point as it was think steel there and a short distance from the battery, so i bolted it to that using the existing bolt.
small rusted wire compared to new battey cable..
just need a new pair of terminals now and im sorted..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: Body/Chassis ground upgrade.. do it!
Post by Edweird » Sat Sep 15, 2012 9:10 pm
Can you show me the new earth point? I've got earthing problems too. I experimented with a spare bit of cable on the headlights and a bigger earth wire made them brighter.
Jay18
Post by Jay18 » Sat Sep 15, 2012 9:19 pm
make sure you remove the clutch cable mount and clean the metal and everything and use battery cable works great mate huge difference...
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Edweird » Sun Sep 16, 2012 9:59 am
Oh, I see, the mounting thing. Thanks. I shall go find myself some suitable cable.
Jay18
Post by Jay18 » Thu Sep 20, 2012 6:53 pm
let me know when youve done it and if its made a difference, it did for me..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Christoff
Post by Christoff » Thu Sep 20, 2012 10:06 pm
An easy way to find bad connections, poor earths, high resistance circuits is a simple. Volt drop test
All you need is a volt meter or multimeter set to volts DC
It's easy because you connect the meter in parallel with the circuit and can test for faults in the +ve & -ve side of the circuit
Connect one lead to B- and the other to chassis ground. You are making a second path or the current to flow, since electricity always follows the path of least resistance there should be 0 reading on the meter as it should all be going down the original earth lead
If you have a voltage reading then the earth is poor because the voltage is finding its way down through your meter instead of the proper earth wire.
Works +ve to +ve as well like checking power to a component.
Always remember that the best earth on the car is the battery -ve post.
