Lazy's samurai build
lazy rambler
Re: Lazy's samurai build
Post by lazy rambler » Mon Jul 30, 2012 11:50 pm
The engine swap is getting there now, the old engine is out, the gearbox has been seperated and pressure washed, just got to put it all together again now.
Now a build in progress
lazy rambler
Post by lazy rambler » Fri Sep 07, 2012 9:48 pm
My su manifold turned up today, so I'll be cracking on with the rest of the engine change this weekend
2012-09-07 17.51.53.jpg (1.14 MiB) Viewed 14865 times
Post by Edweird » Sat Sep 08, 2012 1:34 am
Nice looking manifold. Is that a Rockwatt? It looks fairly well port matched to me.
lazy rambler
Post by lazy rambler » Sat Sep 08, 2012 6:32 pm
Yep that is a Rockwatt manifold and it's now fitted with the SU attached.
Also how can I tell if my starter is a skinny one. I've 'offered it up' and looks like it will only just fit. How do I make sure it's the right kind, after seeing ScottieJ's post in another topic (can't remember what one) I'm not too worried if it's not.
Post by dan_2k_uk » Sun Sep 09, 2012 12:06 am
From the look of the previous photos when you removed it it looks like a rather fat one to me.
Dan
Post by ROBBIE » Sun Sep 09, 2012 3:28 pm
Looking at pic DSC01092.JPG I would say thats a fat starter
lazy rambler
Post by lazy rambler » Sun Sep 09, 2012 6:06 pm
Just measured up for some new pipes to order tonight, getting close now.
This is my current starter.
Post by dan_2k_uk » Sun Sep 09, 2012 7:55 pm
Thats a fat one dude.
lazy rambler
Post by lazy rambler » Mon Sep 24, 2012 3:38 pm
Little bit of an update:
I managed to find a skinny starter on ebay so that solved that problem.
The engine is now in place (well kind of), I am struggling to get the back of the gearbox to line up with the holes in the chassis. It's about 4mm too far back, a bit of brute force and ignorance should fix that.
Manual choke cable and fuel pump fitted, all new hose set fitted.
That's about up to date now. So I'm hoping to be able to fire it up later on this week.
lazy rambler
Post by lazy rambler » Wed Sep 26, 2012 9:59 pm
Got the engine fully fitted now. We managed to get the engine to turn over but it wouldn't fire. I think a day or so fiddling with the fuel mix should get it firing.
