Been running Adda leafs and love the improvement I've got from them, I'm guessing these would feel even better anyone running them?
Cheers Chris
Anyone running potty springs from llama 4x4?
Re: Anyone running potty springs from llama 4x4?
I'v got a set. Went for the 2.5inch lift and had the top leaf made slightly thicker so they would last longer. The ride was ok with them, better than add-a-leafs but you can't expect to much from SJ springs.
They started to lean to the drivers side quite quickley. This is quite common on SJ's anyway, but i think it was made worse as i didn't have the u bolts tight enough and it was causing axle wrap. So can't blame the springs entirely.
