a frames towing
a frames towing
what s the thoughts on a frame towing any pictures designs etc
- turbo-tom
Re: a frames towing
kale wrote:what s the thoughts on a frame towing any pictures designs etc
i used one but the trouble is if you rip and axle off at pay and play etc how do you get back the aa wont touch you because you might not be moted and taxed?
when i used it aswell the old plod were fine never got pulled over but if you do use one you need a big suitible car ie not your averrage hatchback because of the weight etc as many a frames are not braked and as the law says anything over 750kg needs to be braked
my mate dean had his sj not road legal no reg plates etc and a framed his sj had no problems with the bill
but good thing about a frames there alot smaller then a trailer and easier to stoor away but like everything it has good and bad points...
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: a frames towing
yea technically there only supposed to be used to move a broken down vehicle to a safe place to wait for assistance because :-
1. it weighs over 750kg and isn't independently braked
2. it doesn't steer the towed vehicle, it relies on the steering lock being off and the front wheels to follow (by themselves) the cornerline of the towing vehicle
also be aware that you may not be covered on your licence to tow depending on your age and driving qualifications
personally i wouldn't do it but then my truck is usually road legal so I've no need to A-frame
if in doubt, FLAT OUT!
- Highlander
- Can I have a tow
Re: a frames towing
Its illegal
For you to tow a car legally on an A-frame the following conditions must be met :
1) Towed car must be fully road legal, eg. MOT'd, Taxed, insured, legal tyres etc.
2) The combined weight of the a frame and the cars MAM (the maximum load it is permitted to carry, not its actual weight) must be no more than 750Kg
I think only the French made Aixam qualifies on the above weight restriction.
3) The brakes on the towed car must be connected to the A-frame so they operate during braking
4) The car being towed MUST be broken down and the A-frame only used to recover it to the nearest place of safety..
Thats the official line on it, if you use them then you are leaving yourself open to prosecution.
BUT
I've used them for years for towing Samurais to offorad events, picking up and dropping of cars 4x4's and even large vans and never had a problem despite having been stopped by the police and VOSA on many occasions.
BUT
