Indicators causing everything else to dim
Post by dan_2k_uk » Sun Apr 29, 2012 9:33 pm
Havent had a look at this myself yet but on a friends truck at work his indicators are causing everything in the truck to dim when they illuminate.
All the dials go down then up. Dash flashes when headlights are on. Fuel pump is pulsing to the same rhythm aswell.
Apparently he's checked earths and I quickly chucked a spare relay in it for him bit it was hammering it down so I sent him on his way.
Any ideas before I get very wet with a multimeter one day this week.
Dan
Re: Indicators causing everything else to dim
Post by ScottieJ » Mon Apr 30, 2012 1:10 am
I bet he hasn't checked all the earths :lol:
Post by dan_2k_uk » Mon Apr 30, 2012 7:19 am
I know.
Thing is I work with him all the time and he's more meticulous about his work and a better fault finder than me so I kind of have to take his word for it!
Mind you I know where they are located so maybe I will sort it when I look on tuesday.
Dan
Post by Edweird » Mon Apr 30, 2012 6:09 pm
My truck has an earthing problem that I can't trace. It's losing 2 volts somewhere.
Post by dan_2k_uk » Tue May 01, 2012 10:22 pm
After running a fly lead from the battery negative to the rear bulb holders to see if it improved things (which it did) I replaced the earths to the rear lights.
No improvement.
Then had a brainwave that it wasnt doing the same on the front.
Whoever had fitted his engine had removed the main chassis ground and the front lights are earthed to the body.
Knocked up a link to go between the engine ground and chassis and all is now sorted.
MOT for him tomorrow then :salute:
Dan :thumbup:
Post by Darrell » Tue May 01, 2012 10:58 pm
Sorted :doublethumbs:
Don't we just love earth problems, makes them do all kind of strange things :S :S
