Hi, yeah I found this out the hard way, for some reason I thought the wire went off under the passengers seat so when there was nothing there I assumed it was missing, so I took all the steering wheel, plastics and clocks out, I then followed the orange wire from the clocks, as it got down to the fuse box region of the bulkhead it had a connector and changed to a black wire and then went off into the sill and then out again under the drivers seat, and then I found the broken end of the wire under the carpet
but at least it works now
, cheers for the help,
Dan
