oil leak. oil everywhere.
jgp1986
Post by jgp1986 » Sat Feb 25, 2012 7:10 pm
I bought a sj samurai in october and yet to use is as i got it as a non runner project,
Its nearly all finished now and its running but ive got a bad oil leak its constantly dripping off the bottom of the gear box but its run down from behind the head some where, ive change the valve cover gasket but its still leakin as bad where else could it be coming from,
thanks jonno
Re: oil leak. oil everywhere.
Post by Darrell » Sat Feb 25, 2012 7:22 pm
Distributor o-ring, fuel pump breather if the internal seal has failed. Best to get engine cleaner (gunk) or similar and get it all clean, then check for the leak source.
jgp1986
Post by jgp1986 » Sat Feb 25, 2012 7:30 pm
its bad its all over top of bell housing and down the back of the engine,
ill get it cleaned off and see where abouts its coming out of but its hard to see around the back
Post by twiss » Sun Feb 26, 2012 12:15 am
That's not too bad I've had mine like that before.
Just make sure you've got oil in the engine.
As said above it will either be the o ring or the fuel pump. Both dead easy to fix!
Best of luck!
jgp1986
Post by jgp1986 » Sun Feb 26, 2012 12:45 am
Yer it leaks that much i could do with settin a drip up with oil in to keep constantly toppin it up haha,
Ill have a look tomorrow mornin,
Once its all done ill get some pics up :)
Post by Edweird » Sun Feb 26, 2012 1:41 am
Haha! Mine's got an oil leak down the back of the engine too, though the level in the sump never seems to go down :er: I just figured I'd leave it until it got so bad I was losing oil faster than I could put it in.
