My sammy has a large rust hole on the drivers side wing, so i decided to take it out a while ago, but even after taking out all the bolts i couldn't get it off easily, i have not got an angle grinder right now so ended up using a dremel with cutting attachment.
Here is the damage though:
Here are the areas i had to cut at:
And more rust behind the wing
Is there any other way to remove the wing of the samurai?
