wiring in ford altenater
st3f4n
Post by st3f4n » Fri Nov 11, 2011 6:44 pm
Hi all, on the devil vitara engine iv just brought and fitted to my sj there has been a higher voltaged ford altenater fitted. Theres 3 terminals on it. Any ideas or experience on the best way to wire it up.
Re: wiring in ford altenater
Post by ScottieJ » Fri Nov 11, 2011 8:50 pm
You got a photo of the connections and are there any markings on each connection.
st3f4n
Post by st3f4n » Fri Nov 11, 2011 9:46 pm
Ill get a decent pic and note down any marking in the morning and post em up... Cheers bud
st3f4n
Post by st3f4n » Sat Nov 12, 2011 2:49 pm
Just uploading some pics now, Two larger terminals of the 2 one says B+ one smaller terminal which says D+
P.s. sorted the timing and she now runs, Thanks for your help.
Just need to figure the cooling plumbing and she should be sorted
cheers
st3f4n
Post by st3f4n » Sat Nov 12, 2011 5:26 pm
Ok so iv now sat down and looked at it and figured the 2 larger terminals are battery +ve and the smaller terminal is for the dash light... Any hints to what colour the dash light wire is??
P.s correct me if im wrong lol
thanks
Post by Darrell » Sat Nov 12, 2011 5:47 pm
White and red.
st3f4n
Post by st3f4n » Sat Nov 12, 2011 9:16 pm
Thank you!!
Post by ScottieJ » Sat Nov 12, 2011 10:19 pm
st3f4n wrote:Ok so iv now sat down and looked at it and figured the 2 larger terminals are battery +ve and the smaller terminal is for the dash light... Any hints to what colour the dash light wire is??
thanks
Yeah I'd say that sounds right looking at the pics.
st3f4n
Post by st3f4n » Sun Nov 13, 2011 12:00 pm
Any ideas where the Black with white trace wire would go??
Post by Darrell » Sun Nov 13, 2011 12:09 pm
carb solenoid and ignition coil. :thumbup:
