I have been discussing the idea of building a Twin SU set up for the 1.3/1.6 8V engine with a guy from the US as I feel that it would net more power gains than a single HIF44 set up. It will require quite a bit of work to build an inlet manifld but I dont think it is going to be too hard to do, the main problem is that I can't TIG weld so I will be relying on a few favours from my old boss
The idea came about during a disussion on the single SU carb set up as they do not really have SU carbs available easily like we do in the UK and looking at this graph a HIF44 is more suited to 1500cc and smaller. so why not run 2 HIF38s instead?
- SU_vs_disp.jpg (39.86 KiB) Viewed 9004 times
The hardest part to overcome will be re directing the water jackets in a stock inlet but this shouldn't be too hard to do.
- Scale.JPG (139.96 KiB) Viewed 9004 times
Then the idea is to either have the carbs mounted entering the inlet here
- FRONT.jpg (120.79 KiB) Viewed 9004 times
or coming in above the water jacket like so
- Port Top.JPG (145 KiB) Viewed 9004 times
- Front Port.JPG (78.18 KiB) Viewed 9004 times
