bleeding brakes
bleeding brakes
forgot which order
my ride.........
my ride.........
Re: bleeding brakes
Start as far away from the master cylinder/servo as possible, then work towards it
So for a right hand drive SJ:
Passenger side rear
Driver side rear
Passenger side front
Driver side front
Passenger side rear
Driver side rear
Driver side front
Re: bleeding brakes
That's handy.. That's what I've got to do tomorrow. Never had to bleed all four at the same time before.
Re: bleeding brakes
You will need a mate to help!!!
... I really strongly recommend the gunson brake bleeders that work off your spare tyre. Makes bleeding your brakes a 5 minute, 1 person job!
Re: bleeding brakes
I have a little pot, and you fill it half full of fluid, pump the pedal a few times, job done, and a 1 man job.
