Changed the fuel pump but theres something wrong
Re: Changed the fuel pump but theres something wrong
thats it yup
does the fuel return pipe have any difference if blocked off will it run different?
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
No, should run fine with this blocked off. Basically with a electric pump its redundent.
All the electric fuel pumps I read about say the pressure is regulated internally and they don't need a fuel return.
Of course I can't say yours is definately the same though, not knowing the pump.
The pressure of the pump for a carb system should be low anyway.
I've bought myself a new internal fuel tank and have been searching of ways to plumb it in and the answers were on here all along
Start with a pump like this? Ebay Item number: 290688074822
"Diagram Darrell" has been at it again
- fuel pump.JPG (63.39 KiB) Viewed 6838 times
- Edweird
Don't forget to blank the hole. Oil makes a mess.
Thanks Darrell..The plumbing looks easy enough it's just the type of pump.
I think it was Henry that said earlier in this thread that a Facet solid state 3-5psi pump would be best.. The pump item number above is for a 3-4.5psi and others I'm looking at are 4-6psi.
Which is best?
Click Here for Ebay Listing
Just found another thread..Twiss uses one of these
Which is best?
Not sure what the best pressure would be
Sorry about the diagram, it's a bit much really. It's simply enough but it looked like "smalljeep" connected the supply from the pump straight back to the fuel tank
Well I had fun learning how to loose the background from a photo and then post it over a diagram.
I'm easily pleased
I'm easily pleased
Just found another thread.. Twiss uses one of these
(Not sure why my copy and paste ebay thingy isn't working?)
I would think any of those would be suitable, even the cheap one. Though the genuine Facet pump Twiss used may be worth the extra money.
- £45.JPG (15.42 KiB) Viewed 6797 times
- £19.JPG (20.33 KiB) Viewed 6797 times
- £28.JPG (40.01 KiB) Viewed 6797 times
All you need in the copy paste for ebay is the number. If you leave the rest it won't work.
IE: [fleabay] 400292713113 [fleabay]
