Rear disc conversion/Transfer brake
Newtomud
Post by Newtomud » Sun Jun 12, 2011 3:34 pm
:redtin:
Hi, I'm going to have a go at fitting rear disc brakes to my sj and I've just got hold of these brake caliper mountings. = No hand brake on the rear wheels so do I fit a 410 transfer box with a centre brake? 31 inch special tracks = Rock lobster gears while I'm at it? Is there any particular year of 410 transfer box needed?
Silly Questions but I am new to SJ's. Thanks in advance for any advice. :thumbup:
sj brake.jpg (45.03 KiB) Viewed 11806 times
Re: Rear disc conversion/Transfer brake
Post by Darrell » Sun Jun 12, 2011 4:09 pm
What calipers are you going to use? I have read that rover 600 calipers fit and have the handbrake built in, though i think the cables need to be swaped as well.
Newtomud
Post by Newtomud » Sun Jun 12, 2011 4:15 pm
I've got my eye on some original sj calipers. ( Is this good? )
Post by Darrell » Sun Jun 12, 2011 4:17 pm
They should be fine if your going to get a transferbox handbrake. :thumbup:
Post by twiss » Sun Jun 12, 2011 5:49 pm
You have a couple of options really... You can put a 410 drum handbrake on, the only thing you may encounter is difference in flange bolt sizes
Easily solved with either a a flange swap, or by drilling some new holes!
You could also get an x-brake, they are disk handbrakes that go on the same place, and are roughly the same size.
You can get the x-brake from x-eng in horsham, west sussex
http://www.x-eng.co.uk" onclick="window.open(this.href);return false;
There are also other companies that do the disk handbrakes, such as Spidertrax
Spidertrax E-brake Kit
Newtomud
Post by Newtomud » Sun Jun 12, 2011 8:41 pm
As always, Excellent information here... Thankyou :o)
Post by twiss » Sun Jun 12, 2011 11:21 pm
One thing about the x-brake, their downside is they can need a stronger return spring to ensure the brake disengages properly every time...
Or so I've heard..
Henry
Post by Henry » Mon Jun 13, 2011 10:29 am
Darrell wrote:What calipers are you going to use? I have read that rover 600 calipers fit and have the handbrake built in, though i think the cables need to be swaped as well.
The 600 calliper has to be mounted at 2 oclock so the bleed nipple sits at the top
Newtomud
Post by Newtomud » Mon Jun 13, 2011 6:38 pm
I have the calipers now.. They'll need rebuilding first as the're a bit manky.
Highlander
Post by Highlander » Thu Sep 08, 2011 2:41 pm
or 10 o'Clock depending what side your looking at :)
very interesting this, i've got a pair of Ford Scorpio calipers with built in Handbrake that are a perfect fit for the SJ discs, I think Im going to have to fabricate a bracket for them though, rather than use the SJ caliper mounts
