water temperature gauge
Smalljeep
Post by Smalljeep » Thu Jun 09, 2011 5:48 pm
hi there
i recently got a 52mm auxilary gague set and the water temp is the only one left to install the standard gague isnt right apparently a common problem when putting the 1.6 engine in to the samurai.
but i have this other gague for a better reading, but here is the probe connection:
its too big to go where the exhisting sensor went, i see 2 places on the manifold i took out of another vitara, they seem to have wee tubes going to the carb, can i take them sensors off? what do they do? is it possible to have some sort of t junction.
But i also have no heater matrix anymore so there is just a copper pipe connecting the 2 pipes, would there be any sort of connection to plug this onto.
Any ideas would be great thanks.
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Henry
Re: water temperature gague
Post by Henry » Thu Jun 09, 2011 5:57 pm
Id tap the thermostat housing, take the thermostat out and put it in there.
Post by twiss » Thu Jun 09, 2011 9:42 pm
Or get something like this:
Put it in your top radiator hose. The normal practise I think is to have the small sensor for the dash and one in the rad hose for an electric fan
Smalljeep
Post by Smalljeep » Fri Jun 10, 2011 1:47 am
twiss wrote:Or get something like this:
superb, exactly what i was looking but what do you call it? (for the ebay search)
Smalljeep
Post by Smalljeep » Fri Jun 10, 2011 1:50 am
Henry wrote:Id tap the thermostat housing, take the thermostat out and put it in there.
i already have no thermostat inside the housing but the wire going to the probe cant be kinked or cut because it cant be resealed as it has some gas in it.
Post by twiss » Fri Jun 10, 2011 8:05 am
Erm I dunno really... temp sensor housing/adapter?
http://www.x-eng.co.uk/X-Fan.asp" onclick="window.open(this.href);return false;
Smalljeep
Post by Smalljeep » Fri Jun 10, 2011 1:11 pm
i had a rummage on ebay and seen a few but the threaded bit is 1/8" what is that in mm that my calipers read in
Ginger_boy
Post by Ginger_boy » Fri Jun 10, 2011 1:30 pm
Smalljeep wrote:i had a rummage on ebay and seen a few but the threaded bit is 1/8" what is that in mm that my calipers read in
By the way I have read your quote when it says 1/8" thread I suspect the size will not be 3.175mm or 0.125"
If we are talking water senders or oil senders they usualy are fittings with threads like BSP or NPT dia for a 1/8" BSP or NPT will be 9.7mm Outside dia
Smalljeep
Post by Smalljeep » Sat Jun 11, 2011 1:09 am
im confused ill measure the fitting in mm tommorow to see what it is
Smalljeep
Post by Smalljeep » Tue Jun 14, 2011 9:24 pm
my trusty digital caliper is going again, so i had a measure at the temperature sensor thingy for some mm measurements
so is there something or somewhere good to mount the sensor?
