filling gearbox oil
Re: filling gearbox oil
what sort of spanner removes them bolts, is it a square headed thing like the drain plug?
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
I can't remember what it is on the 413/sammy gearbox, might be a 3/4" or 1/2" drive, might be a spanner?
either way I'm sure you'll have one
and its quite easy to get too, you might need a small 1L bottle with the flexy end/nozzle thing to get the oil in there though if you havent got a pump.
like one of these
like one of these
on mine its a nut, drain and filler
on my old t/box it was 1/2" drive
i had 2 of them red bottles i took the gearlever off and put 2 litres into the gearbox. its not grinding so im assuming its ok. but my gearbox has always had this problem, shifting down from 2nd to 1st is very hard, sometimes 1st just isnt there.
i sometimes have same prob goin into 1st try double clutchin it
ahy hitting the clutch twice very hard seems to do it, but the trick seems to get it into second, out and back into second then a quick shove up into 1st.
After a warm up its normally ok, is this caused by something round the selector?
dont know what it is but my old 1 was same, thats where i lernt the clutch trick
was there ever an automatic mated to the g13a engine, that must have been really slow.
No there wasnt, and you will have to double clutch to get it in, mine does it sometimes. Another trick i use with the tractors is make them work in the sticky gears. Big hill big weight, pleanty oh thomas!
what is the actual capacity of the gearbox, was 2 litres enough?
