nasty banging and grinding
Jamie_stafford
Post by Jamie_stafford » Sun May 15, 2011 9:07 pm
hi ive just fitted a new rear diff because i thaut it was the cause of all the horrable noises my sammy has been making but its not, i checkd the prop while it was off and theres no play, am i lookin at a new transfer box or have i missed somthing? :pissed:
Suzuki, because life's to short to be fixing landrovers!
Henry
Re: nasty banging and grinding
Post by Henry » Sun May 15, 2011 9:16 pm
Does it happen in 2 or 4 wheel drive or both?
Have you tried taking the rear prop off and driving in 4wd?
Henry
Jamie_stafford
Post by Jamie_stafford » Sun May 15, 2011 10:03 pm
i happens in 2wd and 4wd, i will try it with the prop out, and it sounds alot more serious than a bearing
Post by ScottieJ » Mon May 16, 2011 9:49 am
I presume you checked the rear wheel bearings when you took the diff out? They can make some nasty noises if they have seized or collapsed.
Could be a dry uj on the rear prop, you might not be able to tell until you take the prop off.
Post by ROBBIE » Mon May 16, 2011 9:51 am
sounds more serious than a bearing..........
both bearings :hahaha:
but seriously ive had both go at the same time and that sounded bad and was undiagnosable by sitting in the back whilst out for a drive :er:
Jamie_stafford
Post by Jamie_stafford » Mon May 16, 2011 10:57 am
I will have a good look over it all tonite, the bearings seemed ok when the half shafts were out but im no expert, i will try and post up a video of it, it sounds rather grusome! Lol
Post by ScottieJ » Mon May 16, 2011 11:54 am
The best way to tell with rear wheel bearings is to jack the wheel up, hold the tyre at the top and bottom and give it a wobble, I wouldn't worry if you can feel small amount of movement but if its gone there will be quite a bit, also give the wheel a spin while its In the air and you'll hear it if its gone.
Jamie_stafford
Post by Jamie_stafford » Thu May 19, 2011 5:18 pm
i just jacked up the drivers side wheel and gave it a spin, sounded nasty so out came the half shaft and its the wheel bearing! i shold of looked a bit closer when it was all out before. thanks for all the help chaps.
Christoff
Post by Christoff » Thu May 19, 2011 8:39 pm
Both mine are gone and have been for months!
How did you get the shaft out bro?
Jamie_stafford
Post by Jamie_stafford » Thu May 19, 2011 9:41 pm
just take the brake drum off then undo the 4 nuts that hold the back plate on, get a slide hammer on the end of the half shaft and tap it out, i was lucky i got the bearing thru the hole of the back plate so i could leave all the breaks connected.
