hi guys
hi guys
This is a list of modifaction of which i have done to it:
truck cab coversion
recaro seats
snorkel
2" pro comp lift kit (exspensive lifting version)
d-flex front and rear shackles
longer shocks and center mounting in rear
extended brake lines
3 point harnesses
6 point external rollcage
electric fan
fuel tank in pick up bit
30mm wheel spacers all round
exhaust exist up out back
235 80 15 offroad tyres (just like maxxis mudzillas)
just replaced engine to a 1.3 and in the procces of fitting an su carb
i am also going to weld the rear diff up when i have sorted the carb out, i will try and get some pics on as soon as possible.
cheers
Re: hi guys
Nice little toy you have there, actually looks pretty tidy for a pay and play only sj
Re: hi guys
howdy
to the club sounds like agood truck
Re: hi guys
Re: hi guys
thanks for the welcome, it is a tidy lil truck for its age and it has no rust and would be easy to put on the road (put lights and plates on it which i still have) but i cant afford to run 2 cars at the mo. planning on getting it up and running with the su carb properly next bank holiday and then welding up the rear diff.
