rear disk pads
- urbanzook
- Winching along now
rear disk pads
i put new pads an disks all round my sj an the rears have worn down 2 metal an the fronts look new.???
ain't it meant to be the front you use the most??????
what could cause this?
Re: rear disk pads
are the rear pads all worn down, ie both pads on each side or is it just 1 pad per side?
Re: rear disk pads
sounds like the brakes are running a bit lame!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
- urbanzook
Re: rear disk pads
both pads on one side worn.
not checked the othere side guna 2 night so ill let ya no
but looks ok.
but looks ok.
- urbanzook
Re: rear disk pads
ok just checked all 4 sets there was one pad with excessive wear.
passanger rear inner pad.
did notice that all 4 rear pads where worn wonky.
- pads.jpg (75.93 KiB) Viewed 10614 times
Re: rear disk pads
blimey they are worn! how long did it take 2 get them that low? they all seem very low and if the fronts are still ok must be something holding them on. are the dics blue'd ? would be if calipers are sticking causing over heating, if not try the load compensator may be your doing most of your braking on the rears. hope this helps.
- urbanzook
Re: rear disk pads
i changed them all six months ago the frunts look new an the backs are as you see them.
there is no blueing off the disk.
i think the hangers are sitting wonky an the pads are not sitting right.
wearing them unevenly fast.
Re: rear disk pads
defo sticking on think you need a service kit or 2
- urbanzook
Re: rear disk pads
i must add i also had all 4 callipers re-bilt
Re: rear disk pads
how have you done your rear disk conversion, from the way the pads are worn it almost looks like the callipers are not sitting square to the disks?
