Is there any dif between the 410 and 413 loom?
Im looking to fit a vit 1.6 and i know 413 loom will work but im unsure if the 410 will?
410 wiring
Re: 410 wiring
Is your 410 a jap? If so there is ax sticky at the top of this section
It should be pretty much exactly the same for a Spanish one except the alternate wiring is slightly different, there are two white(yellow tracer) wires instead of 1 iirc.
Re: 410 wiring
ScottieJ wrote:Is your 410 a jap? If so there is ax sticky at the top of this section![]()
is that the only difference thats good thats good
i dont know what sj it is? didnt have a logbook and dont know how to tell
Re: 410 wiring
[quote="ScottieJ"]Is your 410 a jap? If so there is ax sticky at the top of this section
sorry scottie what do you mean? im abit thick
Re: 410 wiring
Here's a link for you
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =11&t=2100" onclick="window.open(this.href);return false;
