Will SJ samurai jimny brakes lines
Merc8x4
Post by Merc8x4 » Thu Jul 03, 2025 9:40 pm
Hi does anyone know if jimny flexi pipes will fit on a samurai
Thanks in advance
Re: Will SJ samurai jimny brakes lines
Post by ScottieJ » Fri Jul 04, 2025 2:42 pm
Depends if your sj is jap or Spanish built.
Merc8x4
Post by Merc8x4 » Sat Jul 05, 2025 4:46 pm
Ok my flashers are on the left I think. Not sure from which country
Post by ScottieJ » Sun Jul 06, 2025 4:08 pm
Vin starting VSE = Spanish
JSA= jap
Tbh it’s easy to get sj brake flexys anyway so why are you looking at Jimny ones?
Or Dave at llama 4x4 can make you up braided ones (in black) in any length you want, you just need to let him know if your SJ is jap or Spanish and he’ll fit the correct ends.
Merc8x4
Post by Merc8x4 » Tue Jul 08, 2025 12:00 am
I will check vin
Jimny 5” hoses and cheap.
Merc8x4
Post by Merc8x4 » Mon Jul 14, 2025 2:26 pm
Hi VSE Chassis number
Post by ScottieJ » Mon Jul 14, 2025 9:22 pm
Ah in that case Jimny lines won’t work unless you cut off the factory hardline fittings and reflare them with male m10x1 fittings for the Jimny lines.
That’s if your sj still has the factory Spanish female fittings on the ends of the hardlines anyway 😅
Merc8x4
Post by Merc8x4 » Mon Jul 14, 2025 9:26 pm
Ok thanks. Looks like I will have to get some made.
Post by ScottieJ » Mon Jul 14, 2025 9:30 pm
Just check your sj first to make sure it’s still got the original Spanish lines.
Post up a picture in this thread with a pic of the fitting between the hardline and flexies.
