Coiled turqoise samurai 16v
- d_r_1989
- Winching along now
Re: Coiled turqoise samurai 16v
So after today's test drive, iv realised the speedo is quite away out so may need to swap the vitara speedo head for a Japanese sj head. The speedo does read but it's abit slower than actual. Going to do some research and see if it matters or not
Looking and sounding lovely. Is it the calibration between that and the large tires to?
Me and a few of my mates are heading to drumclog on the 18th if you fancy it?
You can calibrate the speedos quite easily if I remember correctly. I’ll try to find the thread with it in.
How do you like the 16v vs the old 8v?
- d_r_1989
Thanks rankine, as much as id like to I don't think I'll get chsnce, though the green one is raring to get out!
I haven't driven it enough to get a proper feel scottie, iv only driven round the block. I can say though it feels alot more responsive and torquey.
Hopefully the speedo will recalibrate quite easy.
I think the next thing to do would be jimny 4.3 diffs and a rocklobster to make better use of the 16v
Whilst it's still in garage iv pulled rear bumper off to give it a clean up. Getting a right overhaul is old girl, suppose it's only fair, been on road 4 years now!
All good man always the next one! Best part of these cars they keep us busy with the follow up work
https://www.suzukiclubuk.co.uk/how-to-t ... ate-speedo
It was in the how to section, pictures aren’t the best but the little lever is quite obvious once you have it apart. It is going to be a bit of trial and error to get it right though.
It might be slightly different on the jap/vit style speedo but I do recall seeing a little calibration lever
- d_r_1989
Definitely keeping me busy! I'm hoping I'm back home at a decent time Friday and can refit rear bumper and lights and then mot Saturday
I'll pull it apart this weekend and give that a try scottie thanks for that. It could well be iv messed it up while I had it in bits resetting mileage.
- d_r_1989
Ye they're such an upgrade to them original seats!
So it's passed it's mot and developed a leak on the rear caliper on the way home, new caliper for £38 and problem sorted.
A couple pics of the caliper setup for anyone that's interested, mx5 calipers are really easy to work with.
Now the rubber mats to cut and we are done for a while
