1985 SJ410 Aisan Carb Issue
Som17y
Post by Som17y » Fri Dec 13, 2024 3:28 am
I’ve been getting a 1985 SJ410 back running after 10 static years.
All going well until, to try and rectify a “bogging down” & very low power/torque issue, I removed the Carburettor and entirely stripped and cleaned it (mistake!). I used a repair kit to replace various bits and then put it back together and reinstalled it.
The car now only runs with the choke @ C20% closed, anything more open and it dies.
Does anyone have a link to info on this carb so I can workout what bit I’ve over or under tightened or done wrong 🤷‍♂️
Or know what the issue could be (I only assume it’s some aspect of reassembly I got wrong)
All screws & adjustable pins etc appeared tight when I dismantled)
Thank you for anyone’s insight
Re: 1985 SJ410 Aisan Carb Issue
Post by ScottieJ » Fri Dec 13, 2024 10:15 pm
I’ll take pics/scan the carb section of the sj410 service manual for you on Sunday or Monday and post them up for you.
Som17y
Post by Som17y » Sat Dec 14, 2024 12:44 am
@ScottieJ - That's very kind. Thank you
I have the Haynes Manual but any further detail on the carb assembly would be hugely appreciated.
kiwitony
Post by kiwitony » Mon Dec 30, 2024 8:48 pm
Hi from New Zealand. Unlikely to help as it's for a LJ80 but here are pages from sections 4 and 5 of a manual - Carb and Fuel related.
Post by ScottieJ » Tue Dec 31, 2024 9:36 pm
Sorry I forgot about this 🤦🏼‍♂️ I’ll try to remember to take pics tomorrow
Post by ScottieJ » Fri Jan 03, 2025 3:53 pm
Som17y
Post by Som17y » Fri Jan 10, 2025 11:58 am
Thank you very much for the info. I'll have a read through
