Vitara inner track rod end
Hi, was wondering if it is possible to replace inner track rod end on 2018 Vitara without special tool and just jacked up
Re: Vitara inner track rod end
You should be able to yes. Just make sure you get the tracking done afterwards.
I would also usually do the outer while it’s apart as well.
Discovered it was steering rack which was worn so replaced, was told quite common on vitara’s, has anyone else had same problem
