the no dosh LJ revamp
Re: the no dosh LJ revamp
Post by donkeychomp » Thu Nov 02, 2017 12:23 am
MOT is friday. Did a check of everything and it all works as it should. Had an issue with a front side light, all fixed now with a bit of solder, plus I had it on upside down and it was dimmer than the other one! Only worry I have is the rear brakes but if that fails I have the shoes in the car and hopefully I can persuade them to fit them there and then.
Post by donkeychomp » Fri Nov 03, 2017 9:58 pm
She passed! :smokin:
No mention of the brakes but an advisory on play in the front hubs...wondering if he means the wheel bearings? Never mind I have a year to get that sorted.
Got a mile away from the test centre and the fog light fell off! Repaired it and it's back on but I will get a new one.
SherwoodNash
Post by SherwoodNash » Fri Nov 03, 2017 10:32 pm
:good: :D
zook123
Post by zook123 » Sat Nov 04, 2017 9:35 am
Awesome, glad to hear it passed!!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by donkeychomp » Sat Nov 04, 2017 10:01 pm
Thanks lads. In 20+ years of owning Suzukis I have never had one fail an MOT. Maybe as I still go to the same place, and the tester loves the LJ...
Post by Anton » Sun Nov 05, 2017 11:41 pm
:doublethumbs:
Post by donkeychomp » Mon Nov 06, 2017 9:38 pm
Anton, long time no see hope everything is as ok as possible for you!
Post by Anton » Mon Nov 06, 2017 11:27 pm
In hospital again, coming home tomorrow. Not having the most fun ever right now, but I should be ok.
Post by donkeychomp » Tue Nov 07, 2017 12:58 am
Give me a call when you get home matey. Long time no see.
Post by Anton » Tue Nov 07, 2017 10:14 am
Will do!
